  • 1 Reply
  • 3085 Views
Gaby301
How do I adjust to day light saving time?
Theoretically you don't - it should be automatic based on the timezone you chose in settings.  If your timezone is not one of the listed ones and you just picked the closest match, you may have an issue that an update would need to provide at some point.  Place a trouble ticket.
