On Friday the custom mode I had created disappeared and the mode changed automatically to disarmed. I did not delete the mode, it has disappeared by itself. How can I get this back? It is quite painful to set it up again!
I had a mode disappear once with adding smartthings integration. I guess it also could occur with the firmware/software upgrades recently. Either way, if it isn't showing up, chances are that you'll need to re-add the mode manually. Sorry
It may be that restarting the base using the power button as well as logging out and back in may have an effect. If not, yeah, unfortunately you'll have to recreate the mode.
