Connection
My base station is connected to the internet. My internet is active. All the 3 lights are green on the base station but when I try logging in, it says, base station isn't connected to the internet. Please help!
Don't have a solution but some people say it depends on whether using a computer browser or app. Can you verify you get no connection using both interfaces?
That's odd.. It should connect automatically.. Unless if your intenet is down..Are you having this issue thru Desktop/Laptop? Mobile devices? Can you surf around internet fine? If you're using a mobile device that have a cellular, does it work by turning off wifi? or Try turning off your cellular and just use wifi, and see if it works.. Also, Try checking your firewall settings and see if anything blocking it, look for both your browser and system settings.. If it still not working, and you did pretty much the troubleshooting that you could then contact netgear support..
Good morning jeetchheda3,
Let's try this, log in to your Arlo account, via the mobile app and tap deactivate.
You will then need to re-add the Serial Number under Subscription | Add a Base Station.
You can use either the PC or the mobile app to re-activate your Base Station.
I would like to understand the steps taken before getting this message from your PC.
What, if any, issues were you experiencing before this error occurred?
I look forward to your response!
Thanks,
DeannS
Arlo Team
if you internet is working, your virus protetion might me blocking Port 80/443
i KEEP GETTING A MESSAGE ASKING ME TO MAKE SURE I AM CONNECTED. I AM CONNECTED AND ALL SYNCED UP
Hi LWILKINS,
Is your Base Station directly connected to a router or a switch? You may post your existing network diagram.
Thanks,
DaneA
Arlo Team
I do have a similar issue did you get a solution since June?
MDS1957,
Welcome to the community! What is the error message you are receiving and are you able to isolate the issue by trying to log in using the Arlo app on a mobile device? If you are getting an error suggesting your base station is not connected to the internet but the LEDs indicate that it is, we are currently looking further into this issue. It seems to be more often than not a browser related problem on the web ui. Please make sure your Adobe Flash Player is up to date and enabled, clear your browser cache and attempt to log back in. Some users have also experienced this error due to active anti-virus software. Let me know if you are still experiencing issues!
Sorted out by "support". Thanks
