Connecting basestation to new fios router
  • 1 Reply
  • 1358 Views
Justmedee
I installed a new fios router and my basestation is not connecting. I can't seem to get to the place to set network connection,
There is no place to set the network connection for a base station or smarthub.  It connects with ethernet to a router LAN port.
Did you remove the base from your account?  (If you did, there was no need to do that - all you needed to do was connect the ethernet cable to the new router).
What base station do you have?  Have you checked the LED status?
