  • 2 Replies
  • 2107 Views
jjp1
Can you connect directly to modem or do you need a router
brh
@jjp1
most modems only have one ethernet port and that is used to connect the router. I think you could plug the base into that port but you should connect to a router.
Brian
It needs an etherent port... if you modem only has one, then why not a switch ( they are cheap as low as $15 , even at walmart ).
As to direct connect, it should work.
