I'm trying to set up the cameras to "arm" (record motion and send notification) between 10 PM and 6 AM. I go into Mode -> Schedule -> click the current "All Motion On" block of hours and change Start Time from 6 AM to 10 PM and Stop Time from 9 PM to 6 AM, but I get a purple X icon on both changes and the Save button is greyed out. Thus I can not change the scheduled time. Am I missing something or is this not possible?
You need to do it in two steps. Schedule does not allow you to go across days in one step.
So do 10pm to 11:59 and then 12:00 to 6am.
I was afraid that was the case. I'll give that a try. Thanks
Also, what's the difference between "Armed" and "All Motion On" in the Schedule screen?
Nevermind, I figured it out - Armed use to be called All Motion On with the old software/firmware and Netgear didn't delete it automatically during upgrade.
If you have ALL MOTION ON along with ARMED, it may be better to remove/delete the "all motion on" mode as some have said it can cause issues at times.
Yup, I did just that. Thanks!
