Cloudy picture
picture looks hazy on security camera, Arlo wireless. Also no blue light when pressing sync button. Unable to do a factory reset. Thank you
Which model camera do you have? It would either use 4 CR123 batteries or have a label inside the battery compartment that starts with VMC.
Provide a screenshot or link to a video that shows the haziness.
VMC3030; that is my living room, on the day time.
should look like this
thank you
should be like this
VCM3030
I see a couple of possibilities:
1) the bright windows may be causing the camera to automatically adjust its exposure, darkening the interior to a useless degree.
2) the camera lens may need to be cleaned.
Does it look ok at night?
