  • 1 Reply
  • 1713 Views
rumate
I have an older base staion VMS3000 and would like to change to a new Arlo Pro Base Station (Model VMB4000).  What do I have to do to make it work?
Depends on what you want to do. If you want to change all cameras over to the new base, you'll need to remove everything from Settings, My Devices and start fresh, using the Add Device button in the Devices tab to claim the new base. Then sync your cameras to the new base and start setting up modes, rules and schedules.
