I am moving to another house. If I plug in the base into the new router will it work or do I have to reset the base and cameras as if I was starting from scratch?
If so, what would be the process to reset everything?
It should just plug in and work fine...at least for 95% of the routers and their settings... sometimes things just get screwed up.
