Changed batteries, camera shows synced but is clicking and cannot be turned on
  • 3339 Views
cweant
I changed the batteries in my camera this morning. It shows synced with the station. It is in a continuos clicking pattern and I am unable to turn it on. Suggestions?
Sounds ominous. Remove the battery and reinsert. Same issue? Open a case with support here for an RMA.
cweant
Yep tried that. Still in a perpetual click between Blue and Amber  at first i thought it was a firmware update but it wont stop. I am going to buy new batteries and try that
cweant,
New batteries is a good start, the pattern you're describing sounds like a firmware update. If the batteries are too low the firmware update may be failing. Please let us know if you still experience the same behavior with a fresh set of batteries.
