Hello Arlo Support,
Just bougth a 4 camera Arlo/Netgear CCTV pack and have setup ARLO account with the new Base Unit.
Previously I had created a Netgear account when I was evaluating the system before buying it. At that time I got a Pasword (auto-generated). I want to change this, but cannot.
I choose settings=>profile and type new password and confirm (2 time), but the Save button is gray - cannot activate.
Thus, I cannot change the password.
Pls. help
Thanks/Jorgen Staal
JorgenStaal,
You must also enter your current password before it will allow you to commit the new password changes.
JorgenStaal,
Hello JamesC,
Thanks a'lot, It works now.
Was it really that simple - I should have figured out myself!
Anyway greatful for your support.
Regards,
JorgenS
I cant find my password and I need to find a way of getting it or getting a new password
darylP2651,
If you have forgotten your password click the Forgot? link on the login screen to reset your password.
For more information take a look at this article: How do I update my Arlo password?
