Cant get sync to work
So I am unable to get my camera into sync mode. I press and release the sync button but can't get it to sync. When I power it up the blue light will flash rapidly then goes solid blue then no led then repeats the cycle.
Jeffrey700,
Which camera model do you have? It sounds like the battery may need charged. Do you experience the same behavior when attaching the charging cable?
