Cant Find Base Station Message
when I go through process it keeps telling me it cant find the base station
What have you tried? What are the LEDs on the base showing? Are you on the same network as the base?
I have the same problem, initially my system was not making recording so I factory reset it and now I am unable to discover the base station
Did you also remove everything from Settings, My Devices? That's required when you reset.
Hi, yes I deleted the camera's and the base station before performing the factory reset.
What are the LEDs on the base showing? Has to be power and Internet as green, maybe Camera as amber. If not, try holding the reset button until the LEDs flash amber and try again.
The next step is to make sure you're on the same network as the router and the base. Use of cell service won't work to set things up. Rebooting the router and base, in that order, may help.
Did you try the reboot of the router?
Open a case with support here. Might be a bad base.
