  • 7 Replies
  • 4019 Views
mmillar1959
Hello - Just moved and re-installing in new house and cant get the base station to connect to internet. I have the cat5 cable into back to cable modem/wireless router but the base station internet light is not activating.
...any help would certainly be appreciated.
thank you
7 REPLIES 7
No color on the Internet LED indicates no connection to the router. That could be a bad cable or a bad port on either the base or the router. Are any LEDs lit? What color?
Make sure the port is functional by running the cable to another device like a laptop.
If good, do a reset of the base ( hold the reset button about ten secs till the front leds flash ) then resync cameras
mmillar1959
I appreciate your response. The RJ45 jack on the cable modem is on. Green. I also switched the cat  5 cable. And, I have two base stations so swapped them out. Also tried holding the reset button 10+ seconds. Nothing I do seams to get the base station to connect to my internet. If you have other suggestions I'd certainly appreciate your help.
thx
Michael
mmillar1959
Thanks for your response. I have two base stations and swapped them both. also swapped the cat 5 cables. and hit the reset botton 10+ seconds on both base stations and nothing I do gets the base station to connect to my internet. The RJ45 port on the cable modem is green. If you have any other suggestions I sure would apprectiate the help.
thank you
Physically take the base over to your router, use the supplied 6 ft cable and plug it in there.. ( eliminates possible cable problems )
After a short while the internet light should come up. Also make sure the required ports are open; Open Ports 443 & 80
mmillar1959
Excellent suggestions.
I have had the base unit on top of router each time I have tried.
Port 80 is open (internet) and 443 is SSL so I cant imagine my cable provide would block 443.
This worked fine in my prior house but for some reason cant get it to connect.
I appreciate you help -
It's not that the ports aren't open, it's that the ports may not be open to arlo.netgear.com.  That's happened before on ISP-supplied routers. The ISP had to change settings to allow Arlo to work.
Did your network equipment change between houses or did you take the original set with you?
