Cannot use Two-step Authentication on iPhone. Field on popup message is too small to see the code.
Cannot use two-step authentication with my iPhone. Field on popup message is too small to see the code. I need to open the message to read the code. When I go back to the Arlo app it asks me to send for another code. An impossible loop I could not get out of. I needed to login on the web to turn i
Hi Catonyg,
Could you show a screenshot where the field on the pop up message is too small to see the code?
