Cannot get the autosetup too work
  • 1 Reply
  • 3230 Views
Houke
Trying to set up my system. Hooked the box in with my Dovado Tiny wireless router and got 2 green lights on the arlo box.
Then started the iphone app and tried too set up a new system but it doesent find anything and after a while it says check your internet settings !!
Also tried plugging into my cisco switch and my netgear extender with same results !!??
Just replied to a similar issue about the router:
You shouldn't need any settings unless you changed them yourself. Ports 80 and 443 need to be open. Sometimes antivirus software blocks ports and certain URLs. A recent issue was solved by opening port 123(?) for NTP.
