  • 9 Replies
  • 4824 Views
Malibu22
Cannot get netgear vmb300 base station to connect to router. Have been using for two years with not problems, has not disconnected from internet and cannot get to reconnect.  Any suggestions?
9 REPLIES 9
steve_t
Master Master
What LEDs are on the base station?
Malibu22
One green one amber
steve_t
Master Master
There should be 3 LED lights on. Can you please say which ones are coloured what? eg Power - green, internet - amber, cameras off
Malibu22
Was power- green, internet- amber, and camera green. Since hitting reset last night, now just two lights on, power-green and internet amber.
steve_t
Master Master
Try a different ethernet cable in a different port and restart your router a few minutes before restarting your base station
Malibu22
I will try a new ethernet cable.  Will be Friday before can do this.  Do you know what type of ethernet cable is needed to replace the one that comes with the unit.  Is it Cat 5?  Thanks.
CAT5 should be fine since the connection is 100Mb/s.
Malibu22
Well, tried new CAT 5 ethernet cable and still no internet connection to basestation.  Guessing the Basestation must just be fried.  Not sure what else to try?
Did you also try a different port on the router? Also, try restarting the router.
An amber Internet LED means it's connected to the router and has an IP address which you can confirm by logging into the router and checking for connected devices. If the router is blocking access to ports 80, 123 and 443bto arlo.netgear.com, you'll need to change the security settings in the router. It's also possible that the ISP is causing the issue. Finally, a bad  ase can certainly be the issue.
