Can you run two Arlo systems from one iPhone app?
  • 2 Replies
  • 9425 Views
Andycis
Hi
Can you run two Arlo systems from one iPhone app? I have two locations I want to monitor so obviously two base stations. I have an Arlo system and looking to get another Arlo pro system.
I don’t want to have to keep logging in and out to access different systems
Yes you can.... upgrade to a higher service level and all cameras, bases will be available to you
As long as you keep the total cameras to 5 or less, you can add as many bases as needed in as many locations as needed and use one account. If going over 5 cameras, you have the choice of subscribing to Premier (10 cameras) or Elite (20 cameras) or create a new account for that second system using a second email address. After you've set up the new system on the new account, use Settings, Grant Access from the second account to the email address of the first. You can then see and mostly manipulate the second system as well as the first in one login.
