Camera pairing failed after resetting Base Station. Any way to make a camera hard reset?
  • 1 Reply
  • 1401 Views
sbrizzo72
Yesterday I needed to reset the Home Station due to a probable system crash. After that I reconfigured the system by reconnetting the HUB first and pairong the 2 cameras I have. To do the pairing I Connect er the cameras one by one to the HUB but unfortunately just one was succesfully paired and I have not succeeded in pairing the other yet. When I do the pairing it starts blinking blue but it is not detected by the HUB even though it is connected by USB cable.
What can I do? Is there any way to make a camera hard reset?
Marco BRILLO
There's no USB cable in use anywhere on your system. You just briefly press the base sync button (don't hold it for 2 seconds) and then the camera sync button. Is that what you're doing?
