I can’t see my synced Arlo device online at ‘My Arlo’ or on my Iphone. The device appears to for have synced properly but I can't see it.
Any advice?
Hankct9,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
Hankct9,
Are you seeing an error message or does the device not show up at all under Settings > My Devices within your Arlo account. What is the LED behavior of the base station/camera when you attempt to sync?
Thanks James
One of the cameras appears to snyc.
Meaning the blue light flashes slowly at first, and then fast blinking like it's syncing.
No error message and show up at all under Settings > My Devices within my Arlo account.
Hope this helps
Hank
Hankct9,
This problem was fixed.
Thanks for the suggestion.
