I can get to my Base station from my iphone app but not the PC Browser app. When I try to access from PC, says that Base station is not connected to the internet, but can access the Base station and Camera just fine from Iphone app. Any ideas on how to solve this problem?
I am having the same issue. I can access from my Android but not on my computer. it's really frustrating because i cannot adjust the cameras from the app.
I think it's a firewall problem on the PC.
It could be the firewall... but have you also tried a different browser? IE gave me trouble, moved to FireFox and Chrome
Try to eliminate the simple things first.
I'm using Chrome but also tried IE - same problem.
Good morning Community members,
Let's try this, log in to your Arlo account, via the mobile app and tap deactivate.
You will then need to re-add the Serial Number under Subscription | Add a Base Station.
You can use either the PC or the mobile app to re-activate your Base Station.
I would like to understand the steps taken before getting this message from your PC.
What, if any, issues were you all experiencing before this error occurred?
I look forward to the feedback!
Thanks,
DeannS
Arlo Team
i had this problem last night but it seemed to go away. I can login from the app but not the URL. The URL said my computer was not connected to the internet in which it was.
I deactivated the base station from my iphone. Then I logged into my account on my PC and tried to re-add the base station as instructed. The base station was not recognized as on the LAN and therefore I couldn't re-add it this way. I was successful in re-adding the base station from the iphone app. I'm suspicous that it's a firewall issue because I was able to access the base station when I temporarily turned off my firewall.
I have now confirmed that it is my antivirus software that is causing the problem. I was able to access my basestation by using another PC that is not running that specific antivirus software package. Also was successful on the original PC when I temporarily disabled protection from that software package.
Since this question pops up occasionally, perhaps identifying the A/V software and the new rule to allow Arlo to work would be of use for others.
I just found something that Works on one of my PC's.
Others should try this and see if it works for them.
NOTE: Internet Explorer and Chrome Still DO NOT WORK!
I was able to get this working in FireFox.
Follow these steps and report back here if it works for you as well. You will need to try this with FIREFOX Web Browser. Latest Version.
Step 1) Go Here and Follow the Steps... https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Step 2) Go Here and Follow the Steps.... https://helpx.adobe.com/flash-player.html
Step 3) In FireFox go to the Menu that looks like a stack of 3 hamburgers at the top right. Then click "OPTIONS" then click "SECURITY" Once on the Security Page click the "Exceptions" button. Add the following websites to the list.
arlo.netgear.com
netgear.com
You will need to do them one at a time. Click the "Allow" button after typing each one. It will populate in the list below. Then Click "Save Changes".
Step 4) Close FireFox. Make sure it has closed then re-open it. I don't believe I cleared Browsing History but if I did you may have to do this also.
Now visit arlo.netgear.com and put in your username and password and see if it works for you.
Good Luck! and please post your results.
NOTE: Also make sure you add the arlo.netgear.com site to the whitelist of your Firewall/Antivirus/Antimalware software.
