  • 1498 Views
Fherly
Can't figure out how to start the video recording. It only play as live but no recording. Pls help, thank you!
steve_t
Master Master
To manually record while livestreaming, you can hit the circular record button.
For all the other times (for normal operation), you need to set the mode to a mode that has recording rules in place
Fherly
Thank's for the reply. But I meant how to record the video 24/7 even if the app is not on. What's happening is when I close the app the recording stop. Pls help thank you
There is no 24/7 recording unless
1) you buy the CVR plan
2) only works on ac powered cameras which the Arlo HD ( 4 123 cells ) is not an option
The cameras are "detect motion then record" types which can be armed 24/7 but it is not continous recording, just when motion is detected.
