Can't Set Record Times
  • 1 Reply
  • 1500 Views
Goodtime
I go into the Mode setting and go to Edit Mode, then Edit Rule.  When I go to the Edit Rule and try and change the length of record time, it sets, then when I save and go back and look it has reset to the default of 10 seconds.  I keep trying to set to 25-30 seconds.  My only option is to set for a "fixed" lenght of time.  I have seen on other Youtube videos that there is an option to record while movement exists.  I do not have that option.  Thoughts and help please.  Thanks.
ShayneS
Goodtime,
The Arlo wire free does not have the option for recording until motion has stopped. The pro & pro 2 have this feature. Have you tried to set the record time for you camera on the Arlo Mobile app or the Web Portal?
