Can't Arm the base after Disarm - Arlo wireless
Hi All,
I just bought the system, it is just regular wireless Arlo with 2 camera, not the Pro version.
- When I clicked on the DISARMED option, the Base went to sleep and I can't ARM the whole thing back, the only option is to reset the Base...very inconvenient 😞
- The battery drained pretty fast, only 12 hours and already down to 82%. I only recored 5 10 sec video and try to view LIVE several times. I guess it is not 4 to 6 months as they advertise for the battery life
- Should I by the Pro version instead? but these set is ony $179 at Costco right now
Are you running on PC or apple or android ?
The Base should not go to sleep. Reboot the base and retest it ...if if happens again you may want to swap it.
Will say that the easiest way to first use the system is by browser and PC, then move to a device.
TomMac wrote:Are you running on PC or apple or android ?
Hi @TomMac I access it via iPhone. After Disarmed the Base, I can't connect to it anymore, the LED on the base was orange isntead of green. After reset , it is green and I can connect to it from both iPhone and PC now.
So what is the Disarm for? will it turn off the Base if choose Disarm?
THANKS
Think you just had a glitch... Disarmed does not turn off the base . Disarmed turns off the motion sense of the cameras to record when they see motion.
Keep an eye on it , all 3 left most leds should be green for working status
BTW, they go from left POWER-INTERNET-SYNC'D CAMERA
PS the usu fix is to turn off then on
