Can't Add Device To Armed Rules
  • 2 Replies
  • 2188 Views
CyberTracy
Always trying to keep Arlo running! Horrible service Netgear! This time I cannot add a device to the “Armed” Rules to have device post motion videos to library. Can add if connected to another camera (if that camera detects motion) but want it by itself. I have checked every possible setting and even disconnected/reconnected camera and restarted base. All others have a rule in place that is working. Updated firmware on this camera too. Can post manual pics but no motion videos posting. Thanks
Try rebooting the base. If that doesn't help, remove the camera from Settings, My Devices and resync. The camera should be automatically added to the Armed mode - you can't add it. You can also try a custom mode - read the FAQs here on how to create and modify them.
CyberTracy
Thank you, that worked. I had tried resyncing once before without success. This time I disconnected the camera, unplugged my base and restarted it, then synced the camera. Shows in Armed rules now.
