Is there a way to set up and instal arlo without fixed line broadband. We are renting and don't have a fixed line coming into the house. We do however have and use a wireless broadband modum.
It struck me as odd that it would be needed, for a product which markets itself as being totally wireless. 🙂
Cheers,
kenn
You could use you cell phone or cell hotspot device as you Internet access as long as you can attach an Ethernet cable to the device for connecting Arlo. Some routers (I have an Asus RT-N66U) support such modems so you don't have to have cable or DSL connections. I haven't used that capability but I don't see why that wouldn't work.
Keco wrote:Is there a way to set up and instal arlo without fixed line broadband. We are renting and don't have a fixed line coming into the house. We do however have and use a wireless broadband modum.
As mentioned, the BASE unit needs connection to a switch/router via ethernet cable.
Seems like im going to have to return it then. Too bad.
Don't wanna try the cell hotspot?
only if an unlimited data plan ! 🙂
These videos aren't THAT large but, yeah...
