Can I wirelessly set up my Arlo Wire-Free system without a router connection?
  • 2 Replies
  • 6270 Views
sjones
Hello Support Team,
I am working in a shared workspace that provides a wireless signal but does not have a router in the area. Is there a way to set up the Arlo without directly plugging the ethernet cord to the router? If not, should I purchase a router specific for the cameras in addition to the one provided?
Thank you in advance for your time and assistance.
-Stephen
manofice
Virtuoso
Virtuoso
The arlo BASE, has to be plugged into a ethernet port, whether it's your router or wireless extender. Any router or extender would do if it has ethernet ports available.
the Arlo Q camera's connect directly to WiFi I believe.
manofice
Virtuoso
Virtuoso
kmiller8821
Luminary
Luminary
Do you have network ports (network connections) available in the facility? If you do, you could plug arlo's base into that network connection. When you say "shared workspace", do you mean at work? Arlo may not work thru a company network depending on firewalls, other network routers, etc.  I'm not sure what you mean by "shared workspace" so if that's not at your office, etc than that may not be applicable to you.
