Can I use arlo camera with an Arlo pro hub
  • 1 Reply
  • 3738 Views
Pgladstone
Hi i am thinking of getting the Arlo Pro and I already have the original Arlo, will I be able to use the standard Arlo cameras with the pro hub? Thanks
manfredz
Hero
Hero
yes you can.  With a PRO hub you'll have the siren and local storage to a USB drive, but you won't have two way voice because thats dependant on having PRO cams.  You could also mix PRO and non-PRO cams
manfredz
Hero
Hero
