Hi i am thinking of getting the Arlo Pro and I already have the original Arlo, will I be able to use the standard Arlo cameras with the pro hub? Thanks
yes you can. With a PRO hub you'll have the siren and local storage to a USB drive, but you won't have two way voice because thats dependant on having PRO cams. You could also mix PRO and non-PRO cams
