Can I mix Arlo productg when setting up? Thinking of Ultra, Pro 2, Floodlight, and Q.
  • 1 Reply
  • 1282 Views
NickWV1
 I am thinking of buying Arlo products for security purposes in a restaurant. Can I mix the products when setting up?
I am thinking of 2 x Arlo Ultra or Pro 2 and a Pro 3 Floodlight for outside.
I am then looking at between 10 - 12 Arlo Q’s.
is this possible and what would I need? Are there different basestations I require?
You can mix and match all the Arlo cameras... if running a newer base as some of the newer camera are not fully backward compatable.
The Pro2, Pro3 flood, Ultra will all work on the newer Ultra Hub.
As to the Q cameras, they don't use a base at all but link into the wifi directly.
All cams will show up int the app.
