  • 2 Replies
  • 1551 Views
Mattch5150
Just would like to know if I set a rule to cross record between 2 cameras, will the trigger camera record as well as the action camera. Ie rear camera triggers and front camera records, will rear camera stillrecord anyway?
ShayneS
Mattch5150,
Just as an example, You can trigger with Camera A & Record with Camera B without recording on both cameras. It depends on how you create your custom mode.
Streak2
Master Master
Yes, if you select record video on the trigger camera then it will also record.
