I have a two Arlo cameras VMS3230 sysytem with no voive or sound. I would like to know if can simply add another camera with sound to my existing wire free network that currently does NOT have sound. I want to use the two no sound cameras in the backyard and the new sound Pro camera on my front porch. Will it work easy peasy or do I need a new system alltogether?
Thanks: Big Ed!
The Arlo PRO camera can be used with the older Arlo base up to the camera limit of your service plan...
( Basic/free) is 5
The audio will work just as on the Pro base.
( Basic/free) is 5
I am having trouble setting up a third camera to my exisitng two. I do all the syncing processes and it says I am sync but the camera does not show up on my arlo computer screen.
Try power cycling the base and close/reopen your app or browser. Also, try both of those to see if it's just a display issue.
