Can ARLO cameras connect to INSTEON system with Hub V2?
  • 1 Reply
  • 4535 Views
CourtneyH
Can someone please confirm is ARLO camera/Smart Security are compatible with INSTEON Home Hub V2?
This does not ask if ARLO needs an ethernet cable connected, bit can the cameras be setup to work with the INSTEON hardware and app?
This questions has been asked previously, however the GURU answer provided is not appropriate and does not actually answer the question: https://community.netgear.com/t5/Arlo/Is-it-possible-to-connect-to-a-Insteon-Hub/m-p/1204096#M27224
Thank you.
I'm not sure exactly what your question is but if you're asking if the cameras can connect directly to the Insteon hub, the answer is no. It requires the base. Thus, any interaction is through software such as IFTTT or Smartthings.
