All three cameras have been successfully synchronised; the Arlo app knows the base station. However, it indicates that no cameras are 'connected'. Base stations supported says "-1", base stations connected says "1". When tapping cameras, I see the instruction about the process of sync'ing cameras. Anyone has an idea how to fix this? Thanks in advance
ET-1, rxod
The engineering team has identified and resolved this issue. Are you still experiencing this behavior?
same problem here. Any help?
ET-1, rxod
Kucke01,
The Arlo team is making several updates to the cloud and to all the apps as a part of the new release today. Some users may experience issues during this process and we apologize for any inconvenience this might cause. We expect the issues to be resolved in a very short time frame.
Fr,
I am having this same problem. Set up the system a couple of days ago and all worked well. Could connect to both cameras and stream video. Email warnings came through without any issues. Then, all of a sudden, it just stopped working and nothing came through. I deactivated the base station and did a factory reset. Reconnected the cameras. Last night I was getting email warnings when the cameras detected movement but the website doesn't show any cameras. This morning, I am getting messages through the Arlo app that motion has been detected but no emails and nothing is being saved to the library.
Will persist with this as I do not want to feel that I've wasted my money.
Any thoughts or suggestions will be very welcome.
I'm based in the UK and my isp is BTinternet.
One thing that seems to always pop up with UK problems is the ISP-supplied hub you're using. The BTHub3 (I think that's the nomenclature) has been problematic. Other users have said the 4 and 5 hubs work fine.
JagFan,
Does content never appear in your library or does it eventually appear after a delay? Is this issue intermittent or does it occur with every motion detection event? Which model modem/router do you have from your ISP? As jguerdat states above, the older BT HomeHub 3 is known the be problematic.
Translation:
I have 5 cameras, until yesterday worked perfect, 5th today said without battery change and they are not recognized. The synchronized flashing blue light goes out but the camera appears
If I understand correctly, you changed batteries on one camera and now won't be seen in your app or browser? Did you try both versions? Try restarting the base station with the power button. You may need to remove the camera in Settings and resync it but that shouldn't be necessary.
