In the last week I updated the app. Have 4 cameras. Since then cameras constantly go offline. Batteries die in one day on all 4 cameras. Have tried restarting base station, opened camera doors and put new batteries, deleted cameras and re-synced them restarting router. Nothing works. Was working great up until recently. Anyone have any other ideas? Or having same issues?
What firmwares are your base station and cameras?
Base station - 1.8.1.1-10234
Cameras all - 1.2.9901
Same here, there was some kind of update and 4 of my cameras wen "offline". I took the batteries out and 3 of them came back to life, one still hasn;t come back online. All of them when from full battery to empty. One I had changed one day before.
Base 1.8.1_10234
Cameras 1.2.9901
OK. Same firmwares as I'm on so I guess that's not the problem. Hit up support
Ok so it's not just mine. I replaced all batteries today at 1:30. 5 hours later 2 show 0% and that's on cameras that are not scheduled "on". I have 1 camera that's on all day and it keeps going offline. I've had this setup for over a year and no problems till now.
I'm chatting with support..... I'm going to replace the batteries in one and see what happens.
Let me know what happens. I've replaced batteries 5-6 times with no change. Maybe it'll work for you
Aaront2,
What is the signal strength for the affected cameras? Poor signal strength or wireless interference can cause the cameras to drop offline, draining more battery than expected. Has anything with your network changed recently (introduction of any wireless devices located nearby/between the cameras and the base station)? Consider relocating your base station limiting (if possible) the nearby proximity of any devices that could be causing wireless interference. If you're still experiencing excessive battery drain, please contact the Arlo Support Team to further investigate this issue.
Aaront2,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
