Cameras going off when setting and disarming
When I disarm my cameras (being completely away from all cameras), motion is detected. When I arm my cameras motion is detected (once again when I'm completing away from all cameras). I don't know what's going on with this.
Hi Arlo824,
Just to be sure, are you saying that your camera is detecting motion when your camera is both armed and disarmed? Are you using a custom mode?
So what is happening is when I leave the home I arm the inside cameras from the garage and from time to time I will get a message stating motion is detected when there isn't anything there. Additionally when I get home and disarm the cameras before even entering the home I get a motion detected message too.
Try removing the battery from your Arlo camera and re-inserting it back in to see if that helps. Otherwise, you might want to try rebooting your Base Station to see if that helps.
