- 2
My cameras do not respond. They show as being "busy". I can't reset. How to I get them to respond? This has happened before and I had to re-sync them. Is there another way?
26 REPLIES 26
Help I have 3 cameras 2 weeks old. Two constantly say busy. Can watch on live view but can't set either for motion detection and neither are recording. What can I do to address the issue? Tried over 3 days. Do I remove device and reload? How do I sync again? Help X
Reset the base using the reset button until the LEDs flash amber. Open and close all battery doors. Go into settings and remove all cameras and the base. Use the Add Device button on the Cameras tab to re-add the base and follow normal procedure for syncing the cameras.
- 2
