Hello I just installed new batteries in my arlo camera . It did turn on and it started updating and I saw the camera turned off . So I took out the batteries and now the camera is not working at all
why did you take the batteries out?
Any chance when you put them back in, you put them in wrong?
I'm seeing the same behavior after I replaced my batteries this AM. I confirmed that the batteries were installed correctly and that each battery has sufficient voltage. There is no activity once the battery door is closed (no lights, yellow or blue).
Please help/advise.
Thanks,
Ken
Sometimes it's because you pushed the batteries down before closing the battery door. Since I've had a couple of batteries stick down I've taken to recommending that you simply place them in the slots and use the battery door to push them down.
