One of My three cameras has switched to showing red pinkish video....? How do I correct this fault and return to normal vide
Message 1 of 3
1,135
The IR filter is stuck. Open and close the battery door. If still stuck, contact support for replacement:
Message 2 of 3
1,106
Message 2 of 3
1,107
There's an easy fix for this one. Turn the camera physically upside down. Then go into the software app and tell it to show 180deg picture. It won't trouble you again.
Message 3 of 3
1,001
