Camera using outside - temperature?
I want to use the camera outside here in Germany.
During the night in winter we can have sometimes -10 to -20 degrees.
What happens with the camera. In the description it is written that you can use it only until -10 degrees.
Kind re
I assume there might beporblems with the battery, if it is too cold, and it is necessary to chenge the battery more often, but is this all? Or can there be other problems, too?
is it possible to use power instead of battery, too?
The camera should operate in cold weather, how cold...? Spec say 14° to 122° F (-10° C to 50° C)
I've has my out in colder weather and it continues to work.This morning for me, it was <10f and the camera is working ok.Tomorrow it will be about 3f.
The problem seems to be more that the lower temps near 0f / < 0f start to effect the battery chemistry.
This lowers the availble power it can draw and can cause a problem... there is no external power option available at this time.
Chilly weather here in Finland for the past three weeks, daily lows around -25 celsius and the highs around -10. So far the alro has survived with no noticable malfunctions. Next week's forecast is promising -30 to -40 celsius....
