Am I missing something? Is it possible I messed up some setting somewhere?
You can share a video with us though. Go to your library. Select a video. Click Share. Click copy link. Come to this forum and paste the link. The link will only be live for 24 hours though
Sugarboss wrote:
None of the above. Another camera clicks and flashes two colors constantly. Never again. This crap costs too much money to not work.
I don't get it. It doesn't work and you don't do anything about it. Why not swap at the store or open a case with support?
Sheesh...
You waited too long - warranty is for one year. There's no fix for a hardware problem other than warranty. You can try popping the camera in your hand, invert it, remove it from Settings, My Devices and resync but if it's stuck, it's stuck.
For the Q that won't sync, hold the reset button until the LED flashes amber, wait till it reboots and try to sync again. Since it may have old firmware, you may need to make sure your WiFi SSID and passphrase use no special characters, just alphanumerics. Once the firmware is updated, you can revert to your normal SSID and passphrase. Use of the router's guest WiFi, if supported, could be useful for this.
The video is shown in pink.
I am expecting regular colored images not pink
This set of four cameras were bought last year
I posed on FB but got no response
been adressed on this forum many times.
First, try opening battery door, wait a minute, then close battery door
jguerdat wrote:
Sugarboss wrote:
None of the above. Another camera clicks and flashes two colors constantly. Never again. This crap costs too much money to not work.I don't get it. It doesn't work and you don't do anything about it. Why not swap at the store or open a case with support?
Sheesh...
The user base is a great first port of call, but yeah, perhaps it's time for you, Sugarboss, to contact support. These sorts of smart home devices do require a small amount to tech savvy to install or troubleshoot. Perhaps a friend or family member could be of help; a teenager? While you've got them there, you could get them to show you how to post a screenshot here, just for future reference. But as my comment above, the system has the ability to share videos from your library. All you need to do is share the link and we can see a specific video from your library. The link is only valid for 24h
If your using an iphone, andriod phone, or a windows phone you already have a free cloud account. They all include them when you setup you apple, google, or microsoft account.
One question..... did you try viewing the cameras on another device, a computer, friends computer, friends phone, family members phone, etc. I ask because doing this and seeing the same results eliminates your phone as a source of the problem. If you don't see pink, then it's your phone.
If you've done all the basic trobleshooting like removing the cameras and base from your account and add them back, rebooting everything, etc, and you still get pink video/image then it sounds like you have a hardware problem. If your past the warranty period then you choices are buy a replacement base/camera, get the base/camera repaired (if netgear has such a service), scrap the system.
I do find it odd that you say the system is "crap". It works flawlessly for me after initial setup and positioning trial and error. And it works for hundreds of thousands of others. It's unfortunate that your having issues, but things do break, it doesn't mean the system is crap. Two people can buy the same car and person A has constant breakdowns over 5 years, but person B has absolutly none. That doesn't mean the car is junk, just that person A got one that developed issues for any number of reasons, bad luck I guess.
If you can get that pic posted or share a video so we can see what your seeing, that would help.
Sugarboss wrote:
Ridiculous. A pink screen is a pink screen. I am plenty tech savvy and these cameras are crap.
Please share a video from your library of the pink screen then
How strange. What kind of phone do you have?
if you mean the videos turning pink, contact Netgear Support... it is the camera
Bought Arlos package new, pink video from day 1, have now wasted 2 hours of my life on phone with support. They sent me a refurbished camera!!!! Ridiculous replacement for a out-of-the-box defective camera. I have now had to call again and now taken down his one camera three times troubleshooting it. Now, they will not send me a new camera. Very unhappy customer $400 deserves better support. Case 289993699. Send me a new camera since your original one was broken!!!
weren't you able to return it to place of purchase since it was new ?
Are you referring to the view and not the blinking light on the camera? If so you might be getting a reflection on the lens. I use Netgear skins on mine and have no problem with lens glare. Some have reported glare with skins made by other companies. Just captured a sunrise on one camera which without the skin probably would have created quite the lens glare.
Just Spent 300 and One Camera out of the box has the red pink tint . Have tried for days to get help on here and phone have got no where . Very Upseting and frustrating. Please help nothing I do fixes and all forums say contact arlo?? They don't answer my emails and 2 hours holding yesterday and today.
you tried opening, waiting, then reclosing the battery cover door? (sometimes need to do a couple times).
If that doesnt work you should contact technical support using one of the methods found by clicking contact support at the bottom of each forum page
so the opening/closing battery cover door trick didn't work? (sometimes have to do a couple times). Can't you return to where you bought from?
it happens to me once every 4-6 weeks but only to the cam I being in every morning and put out at night. every time opening/closing battery cover clears, though once i had to do twice
No I went back to The Store and they said there policy is 30 days!
1  -
1  -
1  -
