Camera problem blinking blue
  • 7 Replies
  • 3113 Views
Houssi4000
Hello everyone
I have a big problem with my arlo camera when i put the batteries it blinks bleu and when i want to sync with the base station the cam doesn’t want to blink bleu . Please tell the solution to fix it and thanks
7 REPLIES 7
Have you tried pressing the camera sync button harder? It's possible that a manufacturing defect is causing the issue. You could swap at the store or use the Contact Support link at the bottom here.
Houssi4000
Yes i ve tried to push harder on the sync button but there is nothing, and the problem that it was working fine when i bought it but now the cam doesn’t want to blink when i push the sync button
Contact support using the link at the bottom here.https://www.arlo.com/en-us/support/contact.aspx
Houssi4000
I did but they didn’t answer me until now they just made a case with numbers and i really don’t know what to do
ShayneS
Hi @Houssi4000
Have you tried to call customer support and Provide them with the case number, they will be able to assist you further. Arlo Tech Support
Houssi4000
I don’t think i can call them because i live in Tunisia but there is an international number ??
The link @ShayneS provided includes phone numbers for various countries (though not Tunisia)
