Camera on/off feature gone. Please help
I had a 2 camera system up and running perfectly. I decided to return the 2 cam system and switched to a 4 cam system. When I switched over under devices there's a gear next to each system and before it had a switch to turn the cam on and off. Each individually could be turned on and off and now with the 4 system I don't have the option anymore. How do I get it back. I think it has something to do with the modes or firmware. Please help. Thanks!
The on/ off switch I think your talking about is under each camera's settings at the top.
if it is not there now, it could be due to needing a SW update, tho the on/ off was done 5-6 months back (?)
Either way you should have the Armed and Disarmed default modes...if you see them labeled as something else, it's def a SW upgrade needed
I'd do the reset trick. Hold the reset button on the base until the LEDs flash amber. Remove all devices in Settings, My Devices and start fresh. Use the Add Device button on the Devices tab to add the base and sync the cameras. Check for firmware updates and then check your Mode tab and see if the default modes of Armed and Disarmed are there.
Follow above and also check out the FAQs on sw updating
The fact that you have ALL ON and don't have ARMED/DISARMED show it's an older SW version ( common due to shipping and sitting on shelf )
I will give this a try later today. Thank
you so much!
