Camera offline
  • 2 Replies
  • 4689 Views
banneheke
One of my cameras are offline. Can I reset with the app?
banneheke
It fixed it self. I didn't have to do anything. It's working fine now.
You can try restarting the base with the app but that's all.  If you have access to the base, I'd use the power switch instead.  If still no luck, you will need to try opening and closing the battery door to reset the camera.  Of course, it's also possible the camera batteries are dead - is the LED on the camera flashing amber slowly?
banneheke
