  • 2 Replies
  • 7070 Views
esimon05
I have one camera that I just changed batteries in and worked fine 4 days ago. Now it will not come on. Need to get this working ASAP
What happens when you open and close the battery door?  It should show blue and then rapid blue flashing.  Make sure the batteries are in correctly and that you have the right batteries.  Worst case, you can remove the camera from Settings, My Devices and then resync it.
Garconis
An issue I noticed is with the Eastshine 700mAh batteries (https://www.amazon.com/dp/B01CHX06YC)
The positive terminal is too short to make contact with the Arlo.Smiley Sad
