Camera not detecting
  • 1 Reply
  • 2963 Views
Vallorie
Luminary
Luminary
The camera is not detecting me.  I came home been out many times.  Not detecting.  I want it in porch ceiling.  Flash not goong off - the manual does not tell me anything other than put it to the side that you want to take which it is side of the front door. I don't live on a very busy street and I was sitting outside on that bench a long time. I kept walking back and forth. If there is a manual it did not come with mine so I downloaded-camera is aim downward right at door and I have issues with people walking across my driveway so I can see what is going on. Folks cut through my property all the time.Porch.JPG
You have to enable the camera first. If the running man in the Cameras tab isn't black it won't do anything. Gl to the Mode tab click on your base and then select the Armed tab. Now the running man should be black and will detect and record according to the settings.
