Camera not detecting/recording motion
I just recently relocated a camera to a better location to cover my front porch area. I will attach a photo to show placement.
As you can see it is positioned "HIGH" and it is only 10 feet (Yes, I measured) away from the camera from the door mat pictured. There is also a harsh angle for someone to pass by on their way up to my front door. By the book, it should be a PERFECT location. YET...it will only record if i walk right up (within 5 feet) and wave at the camera. Sensitivity is set to 100%, and the record time is set to 20 sec. I have 2 other cameras and have NO ISSUES with them doing their job. I have reset camera, the entire system and even installed fresh batteries.
HW Version H7
Firmware1.2.11810
If you swap one of your other cameras to this position, does it work as you want?
