Camera is only 10ft away from base station and drops offline after 48 hours
Camera is only 10ft away from base station. Arlo, is this a fault with the camera? My other two are completely fine. Have tried swapping out etc with same result - reconnects then after 48 hrs goes off line
It would sound like it. I would contact technical support using one of the methods found by following the Contact Support button at the bottom of each page.
