- 2
I installed my system with 3 cameras a few days ago and all was working well. One of my cameras has stopped working. It shows a dead battery. I took the batteries out and reinserted as instructed by other posts on this site. Still not working. I put in new batteries and it still shows dead battery and is unresponsive.
What do I do now?
Not sure what's wrong?
Urb5,
Consider removing the camera and going back through the sync process like when you first sycned it to your system.
Log in to your Arlo Account and navigate to Settings > My Devices > select the affected camera > Remove Device.
After the device is removed. Go through the sync process. Please let us know if you are still having this issue.
I removed the camera and started the sync process, but the camera doesn't do anything once I press the sync button.
The only thing it will do is when I open and close the battery door it blinks once and makes a clicking sound
Nothing else.
I've tried it several times now.
Could the camera be bad?
Urb5,
This could be a hardware issue. Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
I managed to get it reloaded once today and thought it was back up but the screen went back l battery dead when I know they are brand new batteries and show that way in my other 2 cameras.
Alisar,
Have you tried removing this camera from the system entirely and then attempting to sync?
Log in to your Arlo account and navigate to Settings > My Devices > select the affected camera > remove device.
After the device is removed, reboot the camera by opening and closing the battery compartment door (be sure the batteries are fresh) and then attempt to sync the camera to the base station.
I have base station and 5 cameras and have changed batteries many times, now one camera is not working after changing batteries, tried resyncing and still will not work. I need to get this replaced, help
Good luck!
Hi,
My Arlo wireless camera also appears to have stopped working, it is completely unresponsive even with new batteries. My camera is still less than 12 months old.
Can anyone help?
Thanks for the reply. After power cycling, the first two lights are green.
Once I press the sync button the third light flashes green. I don't think it's related to the base, because after putting new batteries into the wireless camera the LED doesn't flash or anything even after pressing the sync button on the camera.
Then it would seem to be a camera issue. Either swap the system at the store or open a case using Contact Support at the bottom of these desktop version pages.
Contact support and open a case.
Try a different browser or the app. There have been a number of recent issues like this - maybe a server issue?
Nope, cuz I was already trying from the app and it's only 1 out the 4.
I have the same issue.
I have five cameras installed. One showed a low battery so I changed the battery, It wouldn't come on...so I changed the battery again.
I now have a dead camera.
Does anyone know how to fix this?
Thanks for the reply!
Tried that too.
The problem is once the new batteries are in the new camera...no status lights turn on nor does it make that little electronic clicking sound the other cameras made once batteries were installed. The base unit cannot see the device.
It's just lifeless.
Open a case with support using the Contact Support link at the bottom here.
- 2
