Camera for VMB4000r3 don't seem to be charging
  • 1 Reply
  • 808 Views
1702Renoir
Hello,
I am trying to set up an Arlo system that I purchased a few months ago. I was able to set up the base station just fine, but I haven't been able to add any cameras to it, and I think it's because the cameras are not charging. When I plug then in, the blue LED turns on, and then it turns off. It says I should get a solid blue light when they are charged. I am leaving them for about an hour each, but the light never turns on. How do I know they are being charged? The LED blinks blue once when I first plug them in, and then it turns off.
Thanks for your help
Dannybear
What model cameras do you have, look inside battery compartment for the VMC number.
if pro or pro 2 then read article below.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
If essential camera’s
https://kb.arlo.com/000062402/How-do-I-charge-my-Arlo-Essential-wire-free-camera
